wire an amp to a stock radio???
Old Mar 11, 2010 | 11:34 PM
96rumbledodge's Avatar
96rumbledodge
Default wire an amp to a stock radio???
i have a 2007 dodge ram with the stock radio i wanna run a single kicker 10in sub with a kicker amp but i dont wanna change out my radio to do it.
I hope this wont be a pain in the butt
what to do?
Old Mar 12, 2010 | 09:41 AM
hemi slappin's Avatar
hemi slappin
lol its very very simple! i have a 10 and an amp with the stock radio in my truck.. i went to the flee market and you can get an RCA box (i dont remember exactly what its called im sorry) but you plug the rca wires from your amp into that box and hook the wires from the box up to your door speaker wires and thats it.. i put my amp under my front and you plug everything in like normal.. ohh and the remote turn on wire idk how to hook that up so i have it looped to the power wire so its always on lol.. but it works and sounds great!! hope this helps
Old Mar 12, 2010 | 09:54 AM
Adam_MA's Avatar
Adam_MA
The device you need is called a line level converter. Also, the remote wire on the amp should be attached to any switched 12V power to turn the amp on and off with the ignition.
Old Mar 12, 2010 | 12:23 PM
96rumbledodge
this will be harder than I think? I was hoping I could just pop the radio out and plug the wires in but of course it's not that eAsy? I guess I'll pay someone to do it
Old Mar 12, 2010 | 03:00 PM
hemi slappin
no man its not hard at all lol you honestly cant mess it up... take your driver side rear door panel off and unscrew the speaker and take it out.. attach the wires from the rca box to the speaker wires then tape or secure some way to the panel then plug your rca wires into the bottom of the box and run the rca wires to wherever your putting your amp and then put the door panel back on and then hook the amp and speaker like you normally would and your done... the remote turn on you can either find a 12 volt on/off power supply or loop it directly to the powerwire spot on the amp (it will constantly stay on that way fyi) its not that har at all dont waste your money paying someone to do it
Old Mar 12, 2010 | 05:19 PM
mike_r's Avatar
mike_r
If you clip onto the wires right behind the radio, you'll get better sound quality because you don't have all the eq and crossover that's going on in the infinity amp (if you have it.) Ether way, going behind the radio would be easier to route wires to the back.
Old Mar 15, 2010 | 07:20 PM
jose13b's Avatar
jose13b
he's right if you live near jersey I will hook you up for free you need to use the wires behind the radio buy the radio wire harness from a autoparts store then pull you radio out plug the harness and look at the new wires from the harness they should match the wires for the high low convertor that you using for the rca's splice the wires on the radio side then put the harness back in the box the take it back and get your 8 dollars back or keep it for a future install of a after market radio
the speaker wires you are looking for should be
driver passenger
front
dark green/yellow (+) gray/yellow
Dark green/LT blue (-) gray/LT blue
rear
gray/LT green (+) Dark green/gray
gray/dark green (-) dark green/LT green
for power use a test light and find the 12 volts at the harness that comes on when you turn the key
Old Mar 15, 2010 | 07:47 PM
jose13b's Avatar
jose13b
this is what you need
http://cgi.ebay.com/DB-HI-LO-CONVERT...item5ad7eae45f
Old Mar 15, 2010 | 07:49 PM
jose13b's Avatar
jose13b
or this one
http://cgi.ebay.com/RCA-Car-Line-Con...item5d2211134b
Old Mar 15, 2010 | 08:01 PM
Marx's Avatar
Marx
this would be the eazyest (i know thats not a word lol)
http://cgi.ebay.com/ebaymotors/Dodge...#ht_3488wt_856
