X Pipe
Old Mar 13, 2010 | 06:16 AM
RamIt33's Avatar
RamIt33
Default X Pipe
I am not digging the X Pipe i put on my truck. The airflow is to smooth and fast and when it comes out its not loud. I just dumped the exhaust before the rear axle and it changed the tone of my truck again. My truck has about a 4X deeper tone than a stock exhaust set up. Dont know what to do next.>.>.>
Need Advise.
Thinking about putting 3inch pipe from the mufflers out the back to see if that would make a better rumble sound.
Old Mar 13, 2010 | 07:50 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I can tell you I just changed my entire system and it is much more deep and rumbly. Go find my exhaust thread.
Old Mar 15, 2010 | 02:44 AM
RamIt33's Avatar
RamIt33
Found your exhaust tread weed. And lsten to your sound clips. That sounds sweet. So weed since you did it that way. What size of pipe should i go back from my mufflers? I am out of funds for the momment but the muffler guy is helping me out for free.
Old Mar 15, 2010 | 03:42 AM
abarmby's Avatar
abarmby
I know it's not the sound you wanted RamIt33 but, a smooth and fast flow is exactly what you need in an exhaust from a performance point of view.
But as in all things in life, it's a compromise.
Fast truck with no rumble........nice rumble but slightly slower.
Lifes important decisions lol.
Al.
Old Mar 15, 2010 | 05:53 AM
RamIt33's Avatar
RamIt33
You are absolutley right!!!!
Old Mar 15, 2010 | 07:40 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Because i am running true duals off my LTs, I am using 2.5" pipe from the front to the back.
Old Mar 15, 2010 | 09:58 AM
truckin151's Avatar
truckin151
Al.
Gotta agree... a nice smooth fast flow is what you are after. Change it to a 3" pipe from the mufflers back and see how that sounds. If you are after a more lopey idle then its time for a lopey cam. If you want to add a deeper tone, its time for some LT's. Mine sounds really nice with the LT's and 3" exhuast (Header Collectors are 3", cats were opened to 3", Y is a constant 3", muffler is a straight through design and is 3" SI/SO and dumped over the rear axle). Going to sound even better after I get my cam in.
Weeds is a mix though as far as sound goes as his has the LT headers, an Lopey Cam and Heads if I remeber correctly which will all change the note of the exhaust.
