air keeps blowing when my truck is turned OFF!?!
Old Mar 15, 2010 | 03:54 PM
a-c's Avatar
a-c
Default air keeps blowing when my truck is turned OFF!?!
I have a 04 Ram 1500 hemi qc, and my problem is...
when i turn my truck off and the vent **** is on any setting it continues to blow air? If i turn the **** to off it stops blowing air, if i leave it on it drains my battery. has anyone experienced this same problem?
Old Mar 15, 2010 | 08:27 PM
reefguy89's Avatar
reefguy89
yea had the same thing happend on my 03. it was a bad ignition switch. it ended up burning the part of the harrness that plugs into it.
Old Mar 16, 2010 | 04:40 PM
a-c's Avatar
a-c
sweet thx! did you have any other problems that resulted from the harness being melted?
Old Mar 16, 2010 | 08:49 PM
reefguy89's Avatar
reefguy89
no i had to go to a junk yard and get the harness from under the dash and splice in the new plug.
Old Mar 16, 2010 | 08:57 PM
mike_r's Avatar
mike_r
Not sure if theres a relay on there, I assume there is. Swap out that relay really quick and see if it still kicks on. You could have a stuck relay.
