HELP with washer fluid sprayers..cont.
So i got the washer fluid sprayers (with LEDs) installed and all wired up. The problem is, is that there not spraying like they should be. Its not the position or the angel or anything like that. It seems as if there isnt enough pressure running to them...
ugh take them off!
if you have to have them on, I would do a little pressure test on them. Take the new ones and old ones (one of each on either side) and try it out. The new heads might be somewhat restricting on the flow
Are you installing these on an import?? I really hope you aren't putting those on your truck... To each their own.. Anyways the holes in which the washer fluid sprays out of might be restricted.. take a toothpick or a sewing needle and stick it in the holes... It will clean them out if something is stuck in there and will open the holes up a lil more
