Installing shocks...need help
Old Mar 16, 2010 | 10:35 PM
HemiNow?'s Avatar
HemiNow?
Would also loke to know when i install the new shock to i install the bottom bolt 1st? Just not sure and this reinstall, like i said there is no hex thing ontop of the Bilstein shocks.
Old Mar 17, 2010 | 10:57 AM
HemiNow?'s Avatar
HemiNow?
Have the new ffront one in but them 3 bolts that hold the shock tower in and are supposed to be self grabbing arnt grabbing they just keep spinning? Any suggestions!?
Old Mar 17, 2010 | 11:51 AM
HemiNow?'s Avatar
HemiNow?
Well fixed that problem with some vice-grips. Now the bottom bolt on the passenger side just keeps spinning. I recommend paying someone to do this job. Too many headaches!
Old Mar 17, 2010 | 03:29 PM
ramhunter9's Avatar
ramhunter9
installing the correct shock is the easiest job on a truck besides oil.
you just had a bad day.
Old Mar 17, 2010 | 04:03 PM
HemiNow?'s Avatar
HemiNow?
That welded nut on the back side broke the weld before the bolt broke loose. i even got a socket in and around the back side and shoved a extension thru the hole and used sockets on both sides but that little bit of weld left would only let my socket get 70% of the way on it and now its stripped. Im stuck and dont know what to do. The last shock too. Everything else is apart on that side except that bottom bolt.
Old Mar 17, 2010 | 04:38 PM
ramhunter9's Avatar
ramhunter9
they should have had a key nut , not a weld . they must have patched it . mine all have key nuts to hold the nut in place while you put the bolt on.
Old Mar 17, 2010 | 04:52 PM
HemiNow?'s Avatar
HemiNow?
maybe thats what it is the bolt is mounted to a little clip thing that slides down in on the back side. anyways that back bolt just turns and turns
Old Mar 17, 2010 | 04:55 PM
bigdaddyII's Avatar
bigdaddyII
Bust out the torch and go to the hardware store and get a new nut and bolt. I didnt realize that swapping shocks could be that much of an adventure.
HemiNow?'s Avatar
HemiNow?
that plate the bolt is attached to has cracked alowing the back nut to turn with the bolt
Old Mar 17, 2010 | 04:56 PM
HemiNow?'s Avatar
HemiNow?
everything went smoth thill this last shock and i dont have a torch
