05 Ram Quadcabb 4x4 1500
Old May 1, 2005 | 02:27 PM
TexasRam's Avatar
TexasRam
Default 05 Ram Quadcabb 4x4 1500
Quick question here guys and gals. 05 Ram 1500 4x4 sits nose heavy. I want to lift the front end to level it out, looking like the ram 2500. Is there a quick fix? SSuch as a front end spring spacer like rancho uses for there 3 inch lifts? or am I going to have to change springs and so on? Maybe a torsion bar adjustment? Someone please help!
Old May 1, 2005 | 05:16 PM
lucky13rme's Avatar
lucky13rme
Default RE: 05 Ram Quadcabb 4x4 1500
Spring spacers will work or you can just crank the torsion bar to level it out, you'll probaBLY want to get an alignment after if you do.
Old May 2, 2005 | 05:29 AM
ross944's Avatar
ross944
torsion keys or spring spacers would be the easiest way to go. I have a 2wd and im just replacing the coil spring, gonna give me atleast 3".
Old May 2, 2005 | 11:01 AM
Vader's Avatar
Vader
I had the local alignment shop crank the torsion bar. Lifted an inch and a half and still rode nicely.
Old May 2, 2005 | 01:41 PM
tommiwan's Avatar
tommiwan
The torsion bars are going to be your easiest/cheapest way to go. One thing to note is after they/you crank the bars you need 2 inch longer shocks or else you will bottom out. You will also need an alignment.
Old May 4, 2005 | 01:01 PM
TexasRam's Avatar
TexasRam
Thanks for the help, I'm taking it to the suspension shop next week, i'll let you know what the reply was.
