3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
you should see a "wear indicator" on the pad. Its a metal peice that sticks out and when the pads wear down to a certain point, the metal thing drags on the rotors creating a squeal. when it squeals, its time to change the brakes. you should also be able to see how long before they start squealing
