weird squeak!!!
Old Mar 22, 2010 | 11:03 AM
Hemi-5.7's Avatar
Hemi-5.7
Default weird squeak!!!
a few weeks ago i started noticing that when i put my truck into drive or reverse from a stop there will be a whining squeak coming from the front end. I only notice it at really low speeds like when im making a turn out of my driveway from a stop. Could it be from the 35's and the lift kit? Any IDEAS?
Old Mar 22, 2010 | 11:38 AM
dirtydog's Avatar
dirtydog
Moderate User
OK, I'm kinda confused? Does the squeek happen when you put the truck in drive/reverse OR when your driving slowly OR both?
Only thing I can think of at a stop are bushing mounts like the trans/engine..etc from the initial torque. My Cheby had almost a chirp/squeek if you will from the rear end bushings.
If when moving, may want to check your tierods out and make sure they don't have excessive play in them or they may be bone dry with no graese in them?????
Old Mar 22, 2010 | 01:30 PM
Hemi-5.7's Avatar
Hemi-5.7
It happens when i first turn the wheel while moving. I can best hear it when im pulling out of my drive way. I have to reverse for about 20 yards while slightly turning the wheel then i can really hear it while in drive making an almost full lock turn out of the driveway. its definitely coming from the front of the car.
Old Mar 22, 2010 | 02:24 PM
southernbnb's Avatar
southernbnb
i have noticed the same kinda thing on my truck. like when i turn right on red on to the highway it makes like a squeek/groan noise.
Old Mar 22, 2010 | 02:44 PM
ramhunter9's Avatar
ramhunter9
lubracation fellas ..dont go in without it!
Old Mar 22, 2010 | 04:44 PM
southernbnb
what needs to be lubed though? maybe the wheel bearing or something? i guess im gonna have to pull the wheel off and look at it on my next day off.
