Terra Grapplers/which sidewall to face out?
Old Mar 23, 2010 | 01:36 PM
Solid_Crimson28's Avatar
Solid_Crimson28
Default Terra Grapplers/which sidewall to face out?
I ordered some Nitto Terra Grapplers 295/60/r20. I noticed that the sidewall writing is different on the two sides. Which side looks better in your opinion? And by the way, i read up on the these tires specs on the nitto website and it says that they are 34.5 in Diameter and 12.36 width. These should fit on no problem right? I also have a 2" tuff country leveling kit installed.
Old Mar 23, 2010 | 02:43 PM
PETE_YK's Avatar
PETE_YK
Unless it were like a trans am with radial T/As, im all for black walled tires!!!
Old Mar 23, 2010 | 03:13 PM
jroy's Avatar
jroy
I have the white letters out on my tires.
Old Mar 23, 2010 | 03:20 PM
kx250frider617's Avatar
kx250frider617
it doesn't matter and the nitto's are black side wall on both side. You won't know a difference just make sure all wheels have the same side out. You might get a little rubbing and i think you for sure have to trim some of the front bumper, nothing big or noticeable, its just the little corner. you'll se where i am talking about
Old Mar 23, 2010 | 11:14 PM
Solid_Crimson28
so you dont think that they will be to wide? does the width even change?
