did I make a mistake?
Old Mar 23, 2010 | 06:40 PM
explorer9950's Avatar
explorer9950
do you guys think there is a strong chance on them rubbing, or its just a "every truck is different" type case?
Old Mar 23, 2010 | 06:42 PM
hoss67's Avatar
hoss67
welll, i am running 305/70/17 starting this coming monday, and they are 12 inches wide and will rub the UCA, becasue i dont have enough backspacing on my stock rims, u need at least 4.5 back spacing for a 12.5 tire to not rub, i have done my research on this, so i had to get spacers for my ram, but also i think the year makes a difference too
Old Mar 23, 2010 | 06:46 PM
HammerZ71's Avatar
HammerZ71
unless someone got the same size tires with a very similar wheel I don't think you are gonna get a real definitive anwser, it's gonna be that close.
While I'm not a huge fan of wheel spacers, my experience is seeing people with lifted 4x4s who tend to play rough.
On a 4x2, I think you'd be just fine if you had to pick some up as long as they are hub centric. Get them on and see if you need them. But you are not going to have much room in there even with the spacers. Almost 35" height and 13" wide is a lot to ask for just a level, even on a 4x4...
Old Mar 23, 2010 | 06:48 PM
explorer9950
true...I plan on gettin a BL, just not at the moment...the new rims have a 4.53 backspacing, so, maybe they will be ok, also its not a true 35" tire, they actually measure at 34.6"...I guess we will just have to see if they do rub, I would only need to get spacers up front?
Old Mar 23, 2010 | 06:50 PM
MikeHTally's Avatar
MikeHTally
What's the offset?
Old Mar 23, 2010 | 07:06 PM
explorer9950
offset is -12mm
Old Mar 25, 2010 | 01:45 PM
97r/tram's Avatar
97r/tram
I only have spacers up front and mine don't rub. I think You're good.
