Lost Power?
Old Mar 24, 2010 | 02:56 PM
Alaskan HemiSport's Avatar
Alaskan HemiSport
Default Lost Power?
Hello everyone,
I was woundering if maybe someone had any suggestions about regaining lost power. A few summers ago I tested out my 0-60 and what i remember most is my tires chirped everytime the engine shifted (its an auto). It has 76000 miles on it.
Last summer i noticed significant power loss so i cleaned my TB and changed my spark plugs and noticed a lot of my power loss come back. Its still not quite there, so is there any suggestions on things i should/need to do to it?
Old Mar 24, 2010 | 03:02 PM
ramhunter9's Avatar
ramhunter9
well since you said TB clean thats out of the way . plugs , wires , filters air and fuel . tire preasure could have been different . outside conditions could also be different .
is it that big of a difference?
Old Mar 24, 2010 | 03:12 PM
Alaskan HemiSport
My truck has Monster exhaust/volant CAI and SC tuner. Last summer... i could barely pull past my dads stock excursion. After cleaning the TB and replacing my plugs my truck was back to doing 0 - 60 in the high 6's so that was much better. I make sure I clean my filter every few months or so. In Alaska the higest grade fuel is 90 octane which sucks. But thats all ive been using for several years now. So if I can replace my wires and double check my preasure it sounds like i should be set.
Old Mar 24, 2010 | 03:15 PM
ramhunter9's Avatar
ramhunter9
use your tunner and put her back to stock run a few miles then re tune it .
Old Mar 24, 2010 | 03:32 PM
Alaskan HemiSport
i'll give that a try today. Thanks for the advice. Im a strong believer in replacing parts with better parts. Are there any spark plugs better then others?
Old Mar 24, 2010 | 04:09 PM
RACERAM9's Avatar
RACERAM9
reset the drive by wire the cpu learns how you drive
turn key on push the gas pedal slowly to the floor (3 seconds)
hold it for 10 seconds relise slowly trn the truck o and enjoy
i do this every so often when i feel her get a little to sluggish
Old Mar 25, 2010 | 10:59 PM
Alaskan HemiSport
Thanks everyone, i've already noticed a difference.
