Leveling Kit Help.
Old Mar 28, 2010 | 03:45 PM
Ranneyn's Avatar
Ranneyn
Default Leveling Kit Help.
I drive a 2003 Dodge Ram. (with a hemi)
its a 2wd, and im going to put a leveling kit on it.
it has to be a 3' to be completely level. do they make 3 inch for 2wd?
i saw one on fatbobs for 70 bucks but its a 2wd..
Anyone have leveling kits, know which ones are reliable, and which websites are reliable? and good prices..
Thanks!
Old Mar 28, 2010 | 03:50 PM
meen green machine's Avatar
meen green machine
dont by the cheap ones on ebay. that have an animated picture of them on the bottom of the spring
Old Mar 28, 2010 | 03:53 PM
explorer9950's Avatar
explorer9950
get the 2.5" daystar on on autotrucktoys.com...I have it on my 07 and a buddy has it on his 03 2wd...actually makes is appear nose high sometimes, but its actually perfectly level..
Ranneyn's Avatar
Ranneyn
hahaha dang man those were the ones i was going for.
yeah bro i know lol
Old Mar 28, 2010 | 03:55 PM
Ranneyn's Avatar
Ranneyn
Thanks explorer! Did you need new shocks or anything?
Old Mar 28, 2010 | 04:02 PM
Matt99's Avatar
Matt99
explorer, you have the 2.5in kit on your 2007 2wd? that means a 3.5in tall spacer? im still having trouble with my 2in kit on my 2007, and I cant see anything taller being able to be run
Old Mar 28, 2010 | 04:25 PM
andrewram2's Avatar
andrewram2
I have a hell bent steel leveling kit on mine. it was $70 for my 2.5". you can order it right off of their site and it seems to be good quality
Old Mar 28, 2010 | 04:47 PM
ramhunter9's Avatar
ramhunter9
anything taller than a 2" will cause you tons of issues like ball joints ect ... it will never ride the same because you are putting to much stress on the suspension parts .
2 ways of making it work . buy a suspension lift and dont install the rear blocks
or use the level you want that is more than 2" and re-due the whole front end .
Old Mar 28, 2010 | 05:59 PM
cwboyjohnny24's Avatar
cwboyjohnny24
Like I believe we talked about, a 2" RC coil setup will level it as well as the 3" rc with the 1.5" blocks. Definitely longer shocks are recommended.
Old Mar 28, 2010 | 07:09 PM
explorer9950
yea...I have a 2.5" daystar spacer, only issues I have are the uca and shock buckets hitting on large bumps...other than that, no issues, and yes, i did get longer shocks..
