07 Transmission 5th gear
Old Mar 29, 2010 | 08:12 AM
bwheelersc's Avatar
bwheelersc
Default 07 Transmission 5th gear
2007 dodge ram 1500 4WD HEMI with 545RFE Transmission.
Does anyone else have trouble getting their truck to shift into 5th gear? I can get it to shift but I have to let off the throttle quickly to get into fifth at or above 65mph. I just did a pan drop and filter change at just over 40k miles. I could tell that the tranny shifts a lot smoother, but no help with 5th gear. Once in 5th, it will stay there and run well and gain speed if desired so I don't think it an issue with enough power. The only way it will shift into 5th on its own is with a downhill, which there arn't many of in western Kansas.
I am wanting to get a Diablo Predator tuner, here before to long but don't have the funds right now. Will this help??
Any opinions or fixes??
Thanks
Old Mar 29, 2010 | 08:40 AM
RedTruck-VA's Avatar
RedTruck-VA
Sounds like you are running tall tires. What size are they?
Old Mar 29, 2010 | 08:51 AM
bwheelersc's Avatar
bwheelersc
They really aren't that big, 285/70/17E's
Old Mar 29, 2010 | 09:10 AM
nateroach's Avatar
nateroach
I have noticed similar shifting from my 07 as well. If you accelerate gradually to 65-70 it doesn't kick into 5th very quickly (same with the Torque Converter), but if you accelerate harder, and let up at your desired speed, it will kick into 5th no problem. I don't know if it is looking for a certain drop in RPM or throttle position before it shifts into 5th or what. I am running a Superchips right now and I am looking forward to the trans options slated to be released here fairly soon so I can tinker with the settings and dial that shift in.
Try accelerating slightly harder up to your highway speed and see if it shifts into 5th easier. I don't have any other issues with the trans, and I am getting ready to drop the pan for my 30K mi change, so we will see if that has any impact.
nateroach
Old Mar 29, 2010 | 10:38 AM
bwheelersc's Avatar
bwheelersc
Sounds like the same issue. Let me know how your trans options are with the superchips. I was thinking maybe there was a flash for the computer or something of that sort. let me know if you figure anything out.
Old Mar 29, 2010 | 11:56 AM
OlDirtyJohn's Avatar
OlDirtyJohn
its just because the stock shift schedule is all kinds of horrible. if you throw a dsp or superchips in there it will make a huge difference.
Old Mar 30, 2010 | 02:04 AM
Duroc's Avatar
Duroc
On my 07' it will shift into 5th at 50mph or so if I let it at normal speeds. I wish it would hit it at 60-65. Sounds terrible when you hit 5th at 50-55 and then mds kicks in.
