Color codes for front door speakers
+12V: Grey / Red
Radio Ground: Black and Black/Light Green
Radio Ignition (CAN data bus) ** See Note
LF Speaker +: Dark Green/Yellow
LF Speaker -: Dark Green/Light Blue
RF Speaker +: Gray/yellow
RF Speaker -: Gray/Light Blue
LR Speaker +: Gray/Light Green
LR Speaker -: Gray/Dark Green
RR Speaker +: Dark Green/Light Green
RR Speaker -: Dark Green/Gray
Im bored with my truck but not bored in life. Im being pushed more information about OB/L&D than I would even think of wanting to know, and they are killing us on the tests
I pmd you this but in case someone else needs it in the future:
Dodge 2006 Ram Pickup EX. CAB Pickup
(PREMIUM SYSTEM)
RADIO HARNESS
Wire Function Color Note Fuse # Size Location
+12V DC Battery(Constant) Gray/red Radio pins 1 & 12 11 20 amp Integrated power module at left front fender
Switched Accessory Data
Ground Black Also black/light green
Left Rear + Dk.green/dk.blue Line level output
Left Rear - Dk.green/orange Line level output
Right Rear + Gray/dk.blue Line level output
Right Rear - Gray/orange Line level output
AMPLIFIER OUTPUTS
12V DC Battery Yellow/red Amplifier pins C1-4 & C1-13 36 25 amp Integrated power module at left front fender
Remote Turn On (input) N/A See notes for B+ & accessory power to subwoofer amplifier.
Left Front Mid + Dk.green/yellow
Left Front Mid - Dk.green/lt.blue
Left Front Tweeter + Gray/orange
Left Front Tweeter - Gray/yellow
Right Front Mid + Gray/yellow
Right Front Mid - Gray/lt.blue
Right Front Tweeter + Gray/dk.green
Right Front Tweeter - Gray/lt.green
Left Rear Mid + Gray/lt.green
Left Rear Mid - Gray/dk.green
Right Rear Mid + Dk.green/lt.green
Right Rear Mid - Dk.green/gray
Center Channel + Gray/brown
Center Channel - Gray/orange
Subwoofer 1 + Dk.green/tan To the subwoofer amplifier
Subwoofer 1 - Gray/tan To the subwoofer amplifier
AT SPEAKERS
Right Rear Mid + Gray/lt.green Or dk.green/lt.green
Right Rear Mid - Gray/dk.green Or dk.green/gray
Subwoofer 1 + Gray/brown Channel 1 of subwoofer speaker.
Subwoofer 1 - Dk.green/brown Channel 1 of subwoofer speaker.
Subwoofer 2 + Gray/white Channel 2 of subwoofer speaker.
Subwoofer 2 - Dk.green/white Channel 2 of subwoofer speaker.
Available Notes
Notes
The SUBWOOFER AMPLIFIER, has B+ at pin 2 (red) with fuse no. 24 of 20 amperes in the integrated power module; the accessory line (pink/yellow) goes to pin 3 & has fuse no. 39 of 10 amperes.
The main amplifier is located at right side of dash, but the woofer amplifier is at left side of body.
(PREMIUM SYSTEM)
RADIO HARNESS
AMPLIFIER OUTPUTS
AT SPEAKERS
Available Notes
Notes
