Aftermarket Head Unit Installation
Old Apr 6, 2010 | 02:52 PM
05_hemiram's Avatar
05_hemiram
Default Aftermarket Head Unit Installation
I have a flip out dvd player lined up for the truck and a friend told me that I'd need a bypass module to hook it up because of the factory unit. Can't really find anything using search. Anybody know about this, or can I just hook it straight up?
Old Apr 6, 2010 | 03:13 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If yuo have the stock Infinity system then you need a certain harness so you can still use the OEM amp. If you dont have that system then you need a slight different harness so your new HU will power your door speakers.
So which is it that you have?
Old Apr 6, 2010 | 04:20 PM
AWE Daniel's Avatar
AWE Daniel
Regular HU, you need this http://www.crutchfield.com/p_1207065...ss.html?tp=736
Infinity, you need this http://www.crutchfield.com/p_120CHTO...ce.html?tp=678
dont buy it from there though, its a big rip
Old Apr 6, 2010 | 04:52 PM
jose13b's Avatar
jose13b
i did not use that bypass you just have to make sure you hook up the blue remote wire for the stock amp so you get sound
Old Apr 6, 2010 | 06:35 PM
05_hemiram's Avatar
05_hemiram
It's a Pioneer, but not quite sure on the model number. Cousin has it installed in his blazer right now.
I don't have the infinity right now, just the regular head unit. Is there still a factory amp in the truck?
Old Apr 7, 2010 | 01:35 PM
AWE Daniel's Avatar
AWE Daniel
If you dont have the infinty 7 speaker setup then all you need is the wiring adapter, just color it all up and youll be fine
Old Apr 7, 2010 | 01:43 PM
Matt99's Avatar
Matt99
no factory amp, the HU is sending the power. I guess you understand the parking brake bypass? Just hook it up
I think its only 06-08 that you have to have the power module deal. It is like 75-150, but like I said, I dont think you have to worry about it
