Adding 3" PA BL?
Old May 27, 2010 | 04:03 PM
  #21
hoss67's Avatar
hoss67
Originally Posted by oefootball_70
SO you gonna get it?
i am going to wait till these tires wear out, becuz i will be throwin on some bigger rubber with the lift
EDIT: and is gettin the gap guards worth it? or can i just grab a few slabs of rubber belt from the coals mines and do the same thing for free?
Old Jun 1, 2010 | 01:33 PM
  #22
JMaxx93's Avatar
JMaxx93
You can definitely just get some slabs of rubber belt to do the trick. IMO the front doesn't look that bad after the body lift anyway.
Also, I'm not sure why some guys are so worried about trimming the front of the frame. The is absolutely no measurable reduction in frame rigidity from this. The trim is forward of the front-most body mount. Also, the simple relocation of the bumper does more to effect safety/function than trimming and inch off the very tip of the frame. How can you be worried about that, but not worried about the extra 30lb or so that is added to each wheel hub by going with oversized wheel/tire combos?
