Where is the turn signal flasher on a 2008 ram truck
Old Apr 16, 2010 | 08:56 PM
Asesapie's Avatar
Asesapie
Default Where is the turn signal flasher on a 2008 ram truck
Hey Im new to the forum and I'm going to put some led light bulbs in my tail lights on my 2008 ram truck and I can't seem to find the flasher for the turn signals. Does anyone know where the flasher is? Any help would be awesome
Old Apr 16, 2010 | 11:04 PM
matthewbeard's Avatar
matthewbeard
it should run off the brake light bulb
Old Apr 17, 2010 | 05:09 AM
Rojhan's Avatar
Rojhan
Pretty sure there isn't a mechanical flasher anymore. The electronics are nice enough to give you an artificial click sound, though.
Old Apr 17, 2010 | 12:09 PM
Asesapie's Avatar
Asesapie
So if I were to install the led lights the stock electronics would be able to run the led lights no problem?
Old Apr 17, 2010 | 03:26 PM
Bent's Avatar
Bent
I believe the "click" is generated seperately from the flasher function,
park in front of a garage door/wall and put your turn signal on, if you watch the reflection off the wall you'll notice the flashing and the "click" aren't in phase.
