Intake tick issue
Old Apr 20, 2010 | 06:59 AM
STRMC2010's Avatar
STRMC2010
Question Intake tick issue
Alright well I thought I had a problem with a rocker popping but maybe that isn't it. It has a semi rough idle with the CEL on so I took my truck to get an OBD scan and I got P0385 which for some reason it was giving me an #8 misfire. I thought p0308 was #8 anyways. I replaced all the spark plugs and the coil for cylinder #8. CEL is now gone but now I have this loud ticking noise inside my intake. Hopefully you guys could please help me figure this out so I can get my truck back on the road thanks guys. Here is a video to maybe help with the issue.
http://www.youtube.com/watch?v=jz1U9Dr2D78
Old Apr 21, 2010 | 12:37 AM
dirtydog's Avatar
dirtydog
Moderate User
Moved this into your own thread.
That sure made quite the mess huh???..lol
I believe the sound is just echoing inside your intake which leads me to believe that you have possible valve noise??
Aluminum also echoes noise so if you have bottom end noise it can work it's way up to the top.
Hopefully someone can better assist that knows the 4.7's a little better than myself.
Old Apr 21, 2010 | 03:00 AM
STRMC2010's Avatar
STRMC2010
Thanks for moving the thread for me hopefully someone can assist with this issue...
Old Apr 21, 2010 | 06:16 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Have you pulled the valve covers and visually checked everything?
Old Apr 21, 2010 | 02:05 PM
STRMC2010's Avatar
STRMC2010
yeah and both valve covers were okay... as you may have seen I removed the right valve cover and everything was fine. Don't know what else to look for
Old Apr 21, 2010 | 02:25 PM
RedTruck-VA's Avatar
RedTruck-VA
I don't know 4.7 engines. But an old chevy trick for finding valve problems was to push down on the rocker arm using a glove at idle and sometimes you could feel a sticky valve or loose rocker as that rocker would either feel different or have a slight slap. Obiviously the noise is not normal. Keep at it and let us know what you find. Good luck..
Old Apr 21, 2010 | 02:42 PM
rocket23's Avatar
rocket23
well you still have good oil pressure that is obvious, I really coulodn't deceifer what or where the noise was with that vid sorry. Could be a echo from the vavle(s). I dunno on this on sorrry, please let us know what becomes of this issue if anything. thanks.
