got a code question please help!
Old Apr 24, 2010 | 01:44 AM
reddakota34's Avatar
reddakota34
Default got a code question please help!
Code- 0038/H02S Thats whats coming up on my diablo does anyone no what this code is and what i need to do to fix it?2003 dodge ram hemi 4x4 if you need to no that.
Old Apr 24, 2010 | 03:40 AM
JoeHemi's Avatar
JoeHemi
not personally familiar with this code. If you search here or google the code you posted you'll find some more information.
This is what I found
P0038-O2 SENSOR 1/2 HEATER CIRCUIT HIGH
4 sensors are used in our trucks: 2 upstream (referred to as 1/1 and 2/1) and 2 downstream (referred to as 1/2 and 2/2).
Sensor 1 is always upstream or before the cat, Sensor 2 is always downstream or after the cat. Banks are dictated by the location of Cylinder #1. Your 2003 Ram's cylinder 1 is on the drivers side so that would be bank 1. In essence, your faulty 02 sensor is located on the drivers side after the cat.
POSSIBLE CAUSES
- O2 Sensor heater operation
- O2 Heater element
- O2 Heater ground circuit open
- O2 Sensor
- O2 Heater control shorted to voltage
- O2 Heater control circuit open
best bet is to replace the 02 sensor. May still take a couple trips to completely clear the code after replacement. If there is still a problem check for a short in the wiring but most likely its a faulty 02 sensor.
Anyways, thats what I just learned from google. Good luck!
Old Apr 24, 2010 | 10:35 AM
reddakota34
okay thanks, i also got punched out cats does that have anything to do with it.
Old Apr 24, 2010 | 11:40 AM
HammerZ71's Avatar
HammerZ71
Yeah, my guess would be the air reading coming from the punched out cat is too close to the specs of the air reading before the cat, since the cat is now basically a hollowed out tube.
Might be the non-fouler trick would fix you up. If the O2 is faulty, it wouldn't be a bad idea to spend the $5 on non-foulers and put them in with the new O2 since your cats are punched...
Old Apr 25, 2010 | 12:22 AM
reddakota34
Okay thanks, So it aint hurting my truck is it?
Old Apr 26, 2010 | 11:25 AM
reddakota34
Bump...
Old Apr 26, 2010 | 04:12 PM
JoeHemi's Avatar
JoeHemi
Well, since your cats are punched you can get by driving it the way it is, but I'd still recommend getting it taken care of when you can.
Here's a lil explanation of the O2s.
An Oxygen sensor is a chemical generator. It is constantly making a comparison between the Oxygen inside the exhaust manifold and air outside the engine. If this comparison shows little or no Oxygen in the exhaust manifold, a voltage is generated. The output of the sensor is usually between 0 and 1.1 volts. All spark combustion engines need the proper air fuel ratio to operate correctly. For gasoline this is 14.7 parts of air to one part of fuel. When the engine has more fuel than needed, all available Oxygen is consumed in the cylinder and gasses leaving through the exhaust contain almost no Oxygen. This sends out a voltage greater than 0.45 volts. If the engine is running lean, all fuel is burned, and the extra Oxygen leaves the cylinder and flows into the exhaust. In this case, the sensor voltage goes lower than 0.45 volts. Usually the output range seen seen is 0.2 to 0.7 volts. The sensor does not begin to generate it's full output until it reaches about 600 degrees F. Prior to this time the sensor is not conductive. It is as if the circuit between the sensor and computer is not complete. The mid point is about 0.45 volts. This is neither rich nor lean. A fully warm O2 sensor *will not spend any time at 0.45 volts*. In many cars, the computer sends out a bias voltage of 0.45 through the O2 sensor wire. If the sensor is not warm, or if the circuit is not complete, the computer picks up a steady 0.45 volts. Since the computer knows this is an "illegal" value, it judges the sensor to not be ready. It remains in open loop operation, and uses all sensors except the O2 to determine fuel delivery. Any time an engine is operated in open loop, it runs somewhat rich and makes more exhaust emissions. This translates into lost power, poor fuel economy and air pollution. The O2 sensor is constantly in a state of transition between high and low voltage. Manfucturers call this crossing of the 0.45 volt mark O2 cross counts. The higher the number of O2 cross counts, the better the sensor and other parts of the computer control system are working. It is important to remember that the O2 sensor is comparing the amount of Oxygen inside and outside the engine. If the outside of the sensor should become blocked, or coated with oil, sound insulation, undercoating or antifreeze, (among other things), this comparison is not possible.
