Got the lights on Now just matter of wiring (lots of Pics)
Old Apr 27, 2010 | 12:12 PM
rebel61021's Avatar
rebel61021
Default Got the lights on Now just matter of wiring (lots of Pics)
Well I finally got the last set of lights for my light bar, Now just have to wire them all up. Does anybody have any idea what size relay and wire I should run to hook up all 4 lights on the bar to one switch? I am also thinking about a small set under the bar to use as bed lights. I want to run the wires for that possabilty while I an doing the 4 main lights. I also want to do a quick disconnect in the bed incase I need to remove the bar and toneau cover for any reason. OK on to the pics....
Old Apr 27, 2010 | 12:52 PM
KingsMan's Avatar
KingsMan
Sweet lookin' truck!
To figure out the amperage capacity of the relay you need use the following electrical formula:
I=P/E
I is current. E is voltage. P is watts.
Add the watts for each bulb, for example if you have 4 one hundred watt lights, 400 divided by 12 is just over 33 amps.
If you are approaching this current level, use a MINIMUM of 12 gage wiring. I would personally use 10 gage for a safety buffer. Overkill doesn't hurt when it comes to current carrying capacity.
Wire your switch to the relay coil. You can use 18 or 20 gage wire for this since a relay draws very little current. Wire the lights through the relay contacts to a fused source. Never go without the fuse unless you're a firefighter...
Hope this helps!
Old Apr 27, 2010 | 01:55 PM
rebel61021's Avatar
rebel61021
Thanks that helps alot.
Old Apr 27, 2010 | 03:41 PM
TRXHemi's Avatar
TRXHemi
I have two 40 amp relays for my 2 pairs of Hellas. I also did 12 gauge wiring.
