Bad problem when using 4L
Old May 6, 2010 | 11:32 AM
Steve Ruddy's Avatar
Steve Ruddy
For the most part with everyday street drivers. You should NEVER need 4-lo, only 4-hi.
yep, a quick flip into 4 hi woulda done the trick
I'm a little confused about the 4H. Doesn't it need the same type of ability to slip as 4L only it's geared lower. This driveway has a very steep bend.
Your back tire spun because you have an open diff prob. That or you have the stock LSD?
I didn't purchase the truck new. I'm assuming it is the stock differential.
Old May 6, 2010 | 07:36 PM
91StealthES's Avatar
91StealthES
Originally Posted by 98cherryram
Ive pulled boats around that you guys would never put behind your trucks. My dad used to be the northwest boat rep for tracker marine, and for donzi, and for donzi proline. I never pulled them out around the road, but pulling some of those bad boys out of the lake is a little harder than your guys 3000lb fishing boat.
no 4x4 was needed here...
[img/]https://dodgeforum.com/forum/attachments/3rd-gen-ram/8646d1273034530-towing-advice-tow2.jpg[/img]
https://dodgeforum.com/forum/3rd-gen...-advice-2.html
