P0443 Evap Purge Solenoid Circ
Old May 8, 2010 | 01:30 PM
jes2561's Avatar
jes2561
Default P0443 Evap Purge Solenoid Circ
Could anyone tell me how to fix this code and what causes it to come about?? The only thing i done wrong was over fill the tank the last time, could this be the problem???
Old May 9, 2010 | 08:30 AM
jes2561's Avatar
jes2561
I erased the code with the superchip and i am hopeing it wont return. When i filled up last time the gas pump messed up and poured gas all over the ground as well as over filled the tank. I was hopeing someone would charm in and let me know if indeed this was a possibility.
Old May 9, 2010 | 03:53 PM
jarhead03's Avatar
jarhead03
Check or change your gas cap, sometimes thats the problem, Ive been told this code happens also with something inside the gas tank. Also check your hoses underneath the truck on the charcoal canister etc. I did all of these but still get the medium evap leak p0446. The purge solonoid is in the tank I believe, not sure though
Old May 9, 2010 | 06:04 PM
jes2561's Avatar
jes2561
Thx for the reply. I cleared the code and drove it a good distance and it seems to be ok. I allways thought the gas cap would trigger a code but when tightened the code would go away if it was the problem. DO you have to clear the code?? Is that the only way it goes away on a dodge?? I know GM will clear itself in most cases for a gas cap. Thats what threw me off.
Old May 9, 2010 | 06:08 PM
jake7's Avatar
jake7
I keep getting p0442 adn p0445, basically the same problems, hoses, gas cap etc...I erased the code after checking the gas cap (easiest thing to check) but it came back so i will be searching for the hoses and checking clamps next to see if there is a leak or a busted hose somewhere.
I've been told the stock hoses and clamps aren't that great.
Old May 9, 2010 | 06:21 PM
jes2561's Avatar
jes2561
Jake i sure aint an expert on this problem or i would not of asked for help but is your cap OK?? Check engine light is really irritateing when your truck is running awsome .
Old May 9, 2010 | 06:23 PM
jake7's Avatar
jake7
Yea I will have to agree, not an expert here either. The cap seems to fit fine. I posted about my problem a while back and that's when i was told to check the fuel lines and clamps to look for a small leak etc.
