ABS/Brakelight causing radio to shut off and more?????
Old May 20, 2010 | 09:06 AM
meen green machine's Avatar
meen green machine
Default ABS/Brakelight causing radio to shut off and more?????
so this morning on the way to school i got off the freeway and pulled to a stop light and heard a ding and my radio turned off along with my amp my leds inside and speedo stopped working. the other guages worked fine and my lights and my ABS light and my parking brake light came on. i turned the truck on and turned it off and and seemed to work fine again. any ideas?
Old May 20, 2010 | 09:11 AM
cwboyjohnny24's Avatar
cwboyjohnny24
Just thinking out loud here so bear with me. Not sure about the radio and amp unless your alternator or battery is going bad which on some older vehicles I've owned causes lights and just strange stuff to happen like you've experienced.
As far as the speedo and brake lights I would maybe look at the speed sensor and see if it's wet or the connection is loose.
Just a few thoughts.
Old May 20, 2010 | 10:17 AM
meen green machine
ya idk though it just happened all of the sudden and it started dinging. and as soon as i turned it off and back on it was all good again
