abs question....need insight
Old May 23, 2010 | 12:08 AM
texaskook's Avatar
texaskook
Question abs question....need insight
Ok, when I put the leveling kit on the other day I noticed Ididn't have an abs sensor wire clipped to the fender liner on the pass. side. Kinda forgot about it bc of all the cussing & busting of knucks & all....but I replaced pads 2day. No wire. No plug. Nothing. Just a hole in the liner where one (I think) should be. My wrk truck is a 04 dually ctd & I know it has one bc I pull it out of the fender liner every month to do oil change (easier to get to the filter). Someone know something I don't? (about the lack of sensor...lol)
Old May 23, 2010 | 12:22 AM
Shiloh 24's Avatar
Shiloh 24
Do you have 4 wheel abs? Most of us only have the rear abs so you won't even have a sensor on the front, if I stomp the brakes my fronts lock up but the rears don't. Dodge was nice enough to basically wire everything up even though you don't have it, kinda like the fog light holes. All ya gotta buy on the 02-05's is the lights and the switch.
Old May 23, 2010 | 12:27 AM
texaskook's Avatar
texaskook
Not rel sure on the 4 wheel abs... but deffinately have one on the drvs side.(front)
Old May 23, 2010 | 04:07 AM
mudkicker78's Avatar
mudkicker78
If you have no A.B.S. light on, then forget it is there, your all set
Old May 23, 2010 | 12:06 PM
texaskook's Avatar
texaskook
that's kinda what I was thinking...done & done.
