2006 ram with a miss........... i think
Old May 23, 2010 | 02:54 PM
groundhogsniper23's Avatar
groundhogsniper23
Default 2006 ram with a miss........... i think
i have an o6 ram with hemi and has 35k on it and once i start it up to let it warm, a few seconds after startup it idels fine then it get a miss. it acts like its gonna stall but it doesn't idel down any more like its gonaa shut off. if i just tap the gas the truck shakes slightly then goes back to normal but the miss still occurs. after it warms up and i am sitting at idle and i tap the pedal it runs fine but still has the miss. i am thinking maybe plugs or wires but wanted to check to see if anyone had any advice to what this might be.
Old May 23, 2010 | 02:59 PM
OlDirtyJohn's Avatar
OlDirtyJohn
could be a bunch of diff things. plugs, wires, dirty TB, bad pcv or egr, etc.... start with all the basics first.
Old May 23, 2010 | 07:49 PM
cwboyjohnny24's Avatar
cwboyjohnny24
+1 Like Jon said, I would go with the plugs and the basics.
Old May 23, 2010 | 08:18 PM
Big_Wheel's Avatar
Big_Wheel
before you go and buy the plugs.. remove one and see what it looks like first..
is it throwing any codes?
also i've seen bad fuel do that too... run some injector cleaner through and inspect your throttle body for major carbon build up
Old May 23, 2010 | 10:07 PM
groundhogsniper23
ok thanks guys, i tried 3 different fuel companys, sheets, exxon, and e.c. barnes i don't know what exactally they have but it always ran good in my other trucks i had. no, no codes that i know of came up. teh check engine light hasn't came on so no i guess none.
