Is a 2 inch level enough for this truck?
Old May 23, 2010 | 11:00 PM
texaskook's Avatar
texaskook
yep... I went w/Pro Comp ES3000. Then straight to the alignment shop.
The flower pedals are alright...I just have a picture in my head of what I want...
& its not those wheels. I'm going matte-black.
Old May 24, 2010 | 12:17 AM
Matt99's Avatar
Matt99
Here is my truck after leveling it. 2.5in, but close enough. I got new shocks also. Monroe something. And the stock 20s powdercoated. But if you need any help on the install PM me, it will be fairly close to mine
Old May 24, 2010 | 12:30 AM
OlDirtyJohn's Avatar
OlDirtyJohn
2.5 put me a little higher in the front. and FYI since you have a 2wd, you can get shocks for a 2wd 2500 and they are 2" longer to accommodate your level.
Old May 24, 2010 | 12:32 AM
Matt99's Avatar
Matt99
thats what mine are (2500 shocks)...and also forgot to add mine is has a 1.5in block in the back so 2in could put you at level
Old May 24, 2010 | 01:26 AM
texaskook's Avatar
texaskook
I did the 2" and tale of the tape says the front sits 11/16" higher than the back. Imeasured from the center of the wheel to the top of the wheel well. I'm not sure if I will shim the back up to compensate for the difference.
Old May 24, 2010 | 03:55 AM
Freakinkeith806's Avatar
Freakinkeith806
I put at 2 inch level on my truck, turned out pretty great.
Old May 24, 2010 | 08:17 AM
ThatRedDodge's Avatar
ThatRedDodge
ok cool. Did you guys put the new shocks on yourself or did you have a shop do it?
Old May 24, 2010 | 09:31 AM
Matt99's Avatar
Matt99
you do it yourself, its super easy, two bolts on the bottom and one up top
Old May 24, 2010 | 09:35 AM
ThatRedDodge
ok cool, did you level yours yourself or have a shop do it? How much do you think the shops will charge fOr leveling kit install?
Old May 24, 2010 | 09:49 AM
RubberFrog's Avatar
RubberFrog
Mine started out looking like that and look where a level took me! lol
