3" lift Question on leveld 2003 ram
Old May 27, 2010 | 11:22 AM
MexiRam's Avatar
MexiRam
Default 3" lift Question on leveld 2003 ram
Had a question about a 3" Lift. This is my current set up.2003 ram 4x4. leveling keys in front. and 35" Nitto Mud grapplers tires on stock 20" wheels. I leveled the front just enough to clear them 35's It looks good but now I want to install a 3" body Lift I want the truck to be higher.My question is can i keep the leveling keys installed in the front? and also if i do the body lift is there anything else i will need to consider maybe like new shocks, gears or something in the seetring cloumn.
Old May 27, 2010 | 12:20 PM
Blackhawkdoc's Avatar
Blackhawkdoc
Im in the process of trying to find the same answers...So ill def be checking back to this one too
Old May 27, 2010 | 12:30 PM
cwboyjohnny24's Avatar
cwboyjohnny24
You can keep the keys. The bl only raises the body of the truck. The kit should come with everything you'll need from pa. It has the extended steering linkage in the kit already. Running 35's I'd personally say you should at some point look at getting 4.56 gears and don't forget, you'll need 2 sets since the front and back have to match up.
