The Door badges are off, warning naked truck...well almost.
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Are you sure that you dont want it clean like that? Minus the glowing red lights of course
Gaaahhhh! Now I gotta see...it does look pretty sick. I could always remove them and put them back on if I want.
Originally Posted by RedTruck-VA
Here' what I did. I cut the bottom off of the old badge and mounted it in the newer position.
So you removed the part that says "magnum"? Good idea. For my black truck however I like the updated lettering on the badges I got to replace the originals. But like you, I will place them where you did.
Yes cut the "magnum" off. It cleaned up nicely. Used two sided tape. Cheap and easy and if you don't like it, it'll come off easy enough. Also, I shaved the OEM antenna and now use a amplified hidden antenna behind the radio.
yea Im sure they have to repaint the whole quarter....on top of that, if you have a metallic finish they SHOULD repaint the door too, because its impossible to match perfectly.
I have been practicing and might spray some stuff at the end of the week...this pearl metallic black or whatever crap I have is expensive
Yea the guy said he may have to do the entire door too and part of the hood, a little more than i want to pay or can pay for that matter at this juncture in my life lol
