Speedliner vs linex vs hurculiner
Old Jun 4, 2010 | 01:23 PM
2006RAMHEMI1979's Avatar
2006RAMHEMI1979
My buddy paid about 650$ in Canada. Also a long box.
Old Jun 4, 2010 | 01:38 PM
bamataco's Avatar
bamataco
I have had Herculiner,Line-X and Rhino Liner. Line-X and Rhino are both very good products. Plus both were lift time warranteed. Herculiner is only as good as your instillation. I took my time and never had a single problem with it.
I have never heard of Speedliner. I would ask if it is life time waranteed though.
Old Jun 4, 2010 | 05:20 PM
jake7's Avatar
jake7
Speed liner only has a 5yr warranty.. sooo for the $100 extra i think I'll go with the life time and the peace of mind.
Old Jun 5, 2010 | 01:55 PM
bamataco's Avatar
bamataco
If you choose to go with either Line_x or Rhino liner make sure you call both of them. because prices vary across the country. When I lived in Alabama line-X was cheaper. Here in New Mexico, Rhino is $100.00 cheaper.
Old Jun 5, 2010 | 08:39 PM
me0418840987's Avatar
me0418840987
I just had the bed of the 63 ****** pickup Rhino lined, and it looks great. Doesn't scuff, and just hauled home a load of firewood. Hosed it out, and you would think it was brand new. 7 foot box-$450.00.
Old Jun 5, 2010 | 08:47 PM
jake7's Avatar
jake7
there is a line-x and rhino lining place right down the street. I will give them both a call tomorrow and see what they charge..
Old Jun 5, 2010 | 08:52 PM
badblackram06's Avatar
badblackram06
I used to actually spray speedliner. I liked it alot. 350 isnt a bad price. You can pretty much spray in anyway you like, texture, thickness, and color wise. Its as durable as any other liner if not more. The only set back on this bedliner is that it stays wet for up to 3 hours, depending on the outside temp and it takes up to 72 hours to fully cure. Where as linex is dry the second its sprayed and cured within a couple of hours. Our shop switched from speedliner to procoat which is a linex type liner, just because of the cure time was faster on the procoat. If you need any more info pm me.
