2002 ram 1500 trans problem
Old Jun 11, 2010 | 09:45 PM
rskram's Avatar
rskram
Default 2002 ram 1500 trans problem
Hi guys I have a 2002 1500 that gives off a p1776 code from the local auto store diagnostic scanner. I was told that it means the l/r solenoids has high pressure and needs to be replaced and I was also told that all the solenoids are in the valve body and that would have to be removed to get to them. The problem with my truck is that when the truck is in drive from a stop the rpms would rev up to about 2500 but the truck only goes about 5-8 mph in about 20 seconds. Does this sound like a l/r solenoid problem and if it is is it fairly easy to fix? Thanks for the help
