Removing Interior Panels?
Old May 16, 2005 | 04:42 PM
Jeep274's Avatar
Jeep274
Default Removing Interior Panels?
Hey guys. Are there any tricks to removing the interior plastic panels? Particularly where the drivers side seatbelt is housed. I am running some c.b. antenna wire for my dad and would like to put it behind the panels. Do they just pop out, or do the have to slide in a certain direction? I didn't see any screws visible. Thanks in advance.
Jeff
Old May 16, 2005 | 05:25 PM
|3|ackAc|D's Avatar
|3|ackAc|D
Default RE: Removing Interior Panels?
ORIGINAL: Jeep274
Jeff
did you check the handle bars?? onthe middle colom... there are like some caps that pop off and i belive you can unscrew them from there..
Old May 27, 2005 | 02:45 PM
NDW13's Avatar
NDW13
Pop the cover off the upper seatbelt mount and unbolt it, then undo the one at the bottom as well. Follow that by pulling up on the door jamb trim til about 4 clips are loose. Now if you have a reg cab...you have to take the little cargo box out from behind the seat by removing the three screws; two on each side and one in the center. If you have a quad, then obviously the box isn't there so you should just have to pull the panels off....they are EXTREMELY tight. Just make sure that you pull straight on them so they won't warp. Just reinstall them in the order that they came off and you're all wrapped up, hidden wires and all. Good Luck
