2004 Ram 1500 won't start :(
Old Jun 24, 2010 | 12:56 PM
RedTruck-VA's Avatar
RedTruck-VA
Sounds like a neutral safety switch problem. Do you have to push in the clutch or have the trans in neutral? What's the start up procedure for dodge manual?
Old Jun 24, 2010 | 01:04 PM
brettj2408's Avatar
brettj2408
its an automatic im guessing due to the fact he said the box around the letters which i would guess is the PRND321
Old Jun 24, 2010 | 01:11 PM
RedTruck-VA
Good call, I missed that...
Old Jun 24, 2010 | 03:32 PM
DrKilljoy's Avatar
DrKilljoy
Yes. This is an automatic trans. I tried hitting the starter like it was mentioned earlier. No dice there. So next up is to locate and check the starter solenoid.
I talked to the guy at Dodge today, he says that sometimes the valve body gets bent/stuck sometimes if if the truck isn't put into park properly. I dearly hope that isn't the issue.
After resetting the PCM, I'm getting a CEL, so maybe I'll drag it over to Autozone and see what the CEL says.
I'll update with my findings... thanks guys!
Old Jun 24, 2010 | 04:50 PM
DrKilljoy's Avatar
DrKilljoy
Fixed it.
Fuse #23 (15A) PCM etc fuse.
That's what I get for letting the woman tell me which fuse was which.
Old Jun 24, 2010 | 05:22 PM
Gone Fishin's Avatar
Gone Fishin
Glad you figured it out.
BTW,
Mines a 5.7 stick
Old Jun 25, 2010 | 03:36 AM
popdog's Avatar
popdog
BTW,
Mines a 5.7 stick
SO much envy. I couldn't find a good deal on one when i was shopping for my truck - though from what i read the auto trans is a lot more reliable than the g56's when paired with the hemi
Old Jun 25, 2010 | 09:15 AM
HemiLonestar's Avatar
HemiLonestar
BTW,
Mines a 5.7 stick
That's because you got a 2500...so unfair
