Custom End Links
Old Jun 24, 2010 | 04:03 PM
Big_Wheel's Avatar
Big_Wheel
Seen! ....gonna check out princessauto and see if i can fab something up-even though i only have 2.5"lift right now, all i'll have to do is switch out the threaded rod.
btw RF do you happen to know the size the SS threaded rod is, and the size of bolt that goes though the rod end bearing? looks like a 17 or 18mm socket for the head of the bolt but cannot tell through the picture..unless you know if its a 1/2" opening in the rod end bearing
Old Jun 24, 2010 | 04:15 PM
RubberFrog's Avatar
RubberFrog
Originally Posted by Big_Wheel
do you know if they make them for the 1500 or do you have to make them yourself?
The threaded rod is 5/8 fine thread. You won't find it at home depot or lowes, they only carry that size in coarse thread soft steel You'll need to order it from fastenal, grainger, mcmaster carr, or somewhere like that. Make sure you get a hardened rod because cheap soft steel will rust up and bend on you. Plus it will look like crap. I have no idea what size the joint bolts are, mine were already assembled. You typically order those when you order your heim joint, so that shouldn't be an issue.
Old Jun 24, 2010 | 04:23 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Those are still some bad azz links man.
Old Jun 24, 2010 | 04:27 PM
Big_Wheel's Avatar
Big_Wheel
yea princessauto here in canada has them--its awesome, has all specialty tools and fabriction materials--hydraulic cyclinders and stuff like that...basically anything you need to make rollcages to wood splitters
thanks RF
Old Jun 24, 2010 | 05:39 PM
ramhunter9's Avatar
ramhunter9
this is not official until we get a video frog .... everytime you do something the camera should be rollin
Old Jun 24, 2010 | 06:06 PM
AF_HEMI's Avatar
AF_HEMI
Aside from looking cool and being way stronger, whats their purpose? Better roll stability? They look great though. Good job.
Old Jun 24, 2010 | 06:13 PM
RubberFrog's Avatar
RubberFrog
They don't flex like the stock endlinks with the extensions. The truck handles corners a lot better.
Old Jun 24, 2010 | 06:30 PM
AF_HEMI's Avatar
AF_HEMI
You should do a writeup...
or... how much charge to make another set?
Old Jun 24, 2010 | 06:33 PM
ramhunter9's Avatar
ramhunter9
i agree with frog , it does handle better with better links . dodge OEM links are junk .
Old Jun 25, 2010 | 06:16 AM
RubberFrog's Avatar
RubberFrog
How long have you had your links? Did you use any rubber between the control arm and the links, or did yours just bolt up metal to metal?
