Help!!
Old Jul 8, 2010 | 12:57 AM
ljhopp's Avatar
ljhopp
Default Help!!
Today I scanned my vehicle for abs codes and came up with two codes.
The first one was fr sensor circuit failure.
The second one was hydraulic pump circuit failure.
So my question is what are these codes and how do I fix them?
Old Jul 8, 2010 | 06:59 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
What are the code numbers?
Old Jul 8, 2010 | 11:35 AM
ljhopp's Avatar
ljhopp
My scanner didn't give the code number just what the code was.
Old Jul 8, 2010 | 11:55 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
What tuner are you using? it may be easier for you to go to an auto parts store and let then connect their OBD scanner to it and tell you the codes.
Either way, look here for your descriptions and then the second link for resolutions. take the space out of the links to make them work
http://www.dodg etalk.com/forums/showthread.php?t=161312
http://www.dodg etalk.com/forums/showthread.php?t=281188
Old Jul 8, 2010 | 12:10 PM
ljhopp's Avatar
ljhopp
I am using a innova 3160 scanner. I think the code is for the right front wheel speed sensor because I also have p1391 on. Which one of the fixs to the p1391 code is the wheel speed sensors, I have change both the ckp and cmp sensors which did not fix the p1391 light.
Thanks for helping me!!
