any body use these HIDS?
Old Jul 8, 2010 | 11:50 PM
HemiRam1566's Avatar
HemiRam1566
Default any body use these HIDS?
http://cgi.ebay.ca/H13-Xenon-HID-Kit...#ht_9220wt_913
i really want a set and i have heard of some flickering issues and what not but i was j/w if any body has any experience with them or is there a brand name kit thats WORTH buying i want plug and play if possible.
thank you.
Old Jul 9, 2010 | 12:24 AM
dirtydog's Avatar
dirtydog
Moderate User
All HID kits under $200 should be created equal. They are all the same. Those WILL flicker the same as any unless you install a relay harness. It's the canbus system, not the HID's themselves.
check out HIDextra They give you a relay kit for free if you ask. Pretty sure? That or you can install 20watt resistors instead of using the relay kit.
Old Jul 9, 2010 | 01:01 AM
Thatonekidw/theHEMI's Avatar
Thatonekidw/theHEMI
you get what you pay for. Cheap HID's are bright at 1st. But they die out quickly and are also prone to flickering
Old Jul 9, 2010 | 07:30 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Not true. If you have compared bulbs and ballast like I have then you will know most are all made by the same companies and some just happen to get repackaged prettier than others.
However, any bulbs has a recommended replacement factor after so many hours of use.
Old Jul 9, 2010 | 07:58 PM
hemiguyz's Avatar
hemiguyz
Originally Posted by HemiRam1566
i really want a set and i have heard of some flickering issues and what not but i was j/w if any body has any experience hid kits with them or is there a brand name kit thats WORTH buying i want plug and play if possible.
thank you.
I don't have any flickering problems, just need to find a good seller.
