stock gears
Old May 19, 2005 | 06:10 PM
4x4 toy's Avatar
4x4 toy
Default stock gears
what is the stock rear/front differential in a 4x4 ram open or limited slip, if open does anyone know of system similar to aussi lockers that will give me locking axels? also what is the stock gear ratio?
Old May 19, 2005 | 06:17 PM
Drew's Avatar
Drew
Default RE: stock gears
correct if wrong, but since you have a 4x4 you should have 3.92's in the rear and the front.
the best way to tell if you have a LSD in the rear is if you do a burn out and you get two skid marks you have LSD. only one is an open. the front is an open. you can get a locker for the front, but you have to change out the diff.
I have the off road package on my truck and I have an LSD electronic locker in the rear. it engages when I go into 4L that I know and might engage in 4H but I doubt it.
Old May 19, 2005 | 07:03 PM
RedSS454's Avatar
RedSS454
I have the 3.92's but not the LSD (One tire fire!).
one thing I wondered: When in 4WD (electronicly controlled) the turning radius goes down. Is that from the rears locking, or is it something different. Just have always wondered.
Chirs
Old May 19, 2005 | 07:52 PM
DonG's Avatar
DonG
I have 3.55s front and rear. The rear is LSD. You can check the label in your glovebox for your gear ratio and if you have LSD or not. I'm not sure, but I don't think LSD in the front is an option.
Old May 19, 2005 | 09:26 PM
Drew's Avatar
Drew
Front LSD is not offered, but the front electronic locker is standard on the power wagon
Old May 20, 2005 | 04:45 PM
Jcarp's Avatar
Jcarp
My 04 4x4 has 3.92s. There should be a tag attached to the diff case by one of the bolts telling you what gears you have.
