Idle Problems
Old Jul 12, 2010 | 08:55 AM
Ramer05's Avatar
Ramer05
Default Idle Problems
I have a 2005 dodge ram 4.7L and I’m having a problem, starting the truck when motor is cool or hot it will idle up and down up and down up and down but never putting out a check engine code. The problem started after I got another truck to drive back and forth to work and I let it sit for about four weeks just driving it on the weekend, dose any one have any suggestions?
Old Jul 12, 2010 | 09:01 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
https://dodgeforum.com/forum/3rd-gen...-problems.html
same thread
There are lots of threads on idle issues and can range from TB needs to be cleaned, bad fuel (not good to let ethanol blended fuels sit as it absorbs moisture and separates), EGR maybe clogged, vacuum leaks
Old Jul 12, 2010 | 09:02 AM
brettj2408's Avatar
brettj2408
does it feel like it drives rough as well? or is it only idle
Old Jul 12, 2010 | 10:47 AM
Ramer05's Avatar
Ramer05
yeah it fills like its lost some power
Old Jul 12, 2010 | 10:49 AM
brettj2408's Avatar
brettj2408
does it stumble or sputter at any certain speeds?
Old Jul 12, 2010 | 10:50 AM
Ramer05's Avatar
Ramer05
and when i push the throttle and hold it in one it fills like it steps up in power instead of a smooth exceleration
Old Jul 12, 2010 | 10:52 AM
Ramer05's Avatar
Ramer05
yeah every now and then it will sputter like its gonna choke out and then it picks up and takes off
Old Jul 12, 2010 | 11:08 AM
brettj2408's Avatar
brettj2408
i would look into your egr, or your tps
Old Jul 12, 2010 | 11:20 AM
Ramer05's Avatar
Ramer05
i will give both a shot thanks for your help
Old Jul 12, 2010 | 11:21 AM
brettj2408's Avatar
brettj2408
i would diagnose them first, im not telling you to replace them, unless you want to go that route. but diagnosing would help you save some green.
