lower ball joint help
Has anybody had problem's removing the axle out of the way so you can get the knuckle off the lower ball joint. Tryed lubed and heat also used air hammer and this axle still won't move. I'am running out of ideas. It is a 2004 1500 4x4.
Thanks for the help.
