3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I changed the front rotors and pads to powerslot and hawk pads. On the driver side i removered the brake line and then reattached it. I then replaceed all the new parts. I did the same on the passangers side. When i removed the brakeline it lost a lot of fluid. I refilled the brake fuild. then pumped the peddle till it was firm. Then when i tired to press the brake again it was soft and went to the floor. I hope i'am explaining this right. what should I do bleed the entire system?
