60k service on a 06 ram 1500
Old Jul 28, 2010 | 06:34 PM
scott3813's Avatar
scott3813
Default 60k service on a 06 ram 1500
i am haven a hard time finding what i need to know for the maint. on my truck. i got a 06 ram 1500 4x4 with the 4.7L motor. i need to know the types of fluids and the quanity of them.
coolant, transfer case, trans, front and rear diff. any help would be great
Old Jul 28, 2010 | 07:33 PM
dirtydog's Avatar
dirtydog
Moderate User
All of those specs should be located in your owners manual.
I would reccomend all you listed.
front diff...80w-90 Synthetic 2 bottles
rear diff....75w-140 Synthetic 2.25 bottles or 2 bottle and 1tube of modifier
trans...8qts of ATF+4 your dropping the pan only or 17qts if your doing a flush.
Transfer case...ATF+4 I believe it's 3qts you'll need.
coolant should be 2.5 gallons?? of full strength so you can 50/50 mix it.
Geez i need to remember all this chit.
Old Jul 28, 2010 | 07:38 PM
scott3813's Avatar
scott3813
thanks for the help man.
Old Jul 28, 2010 | 09:06 PM
freestyledude's Avatar
freestyledude
Maybe DirtyDogs post should be in the FAQ?
Old Jul 28, 2010 | 09:16 PM
Ironsleeve318's Avatar
Ironsleeve318
Flush Coolant Flush and replace engine coolant at 60 months, regardless of mileage. Inspect Brake Hose/Line Constant Velocity Joint Inspect CV joints (if equipped) and front suspension components. Cooling System Check engine coolant level, hoses & clamps. Exhaust System Fluid - A/T Check the automatic transmission fluid level. Fluid - M/T Check the manual transmission fluid level. Positive Crankcase Ventilation Valve (E) Replace as necessary. Replace Air Filter Element (E) Engine Oil Oil Filter, Engine Spark Plug (E) Rotate Tires
(S) = Service Warranty Requirement
(E) = Emission Warranty Requirement
(B) = Both Service and Emission Warranty Requirement
Pulled off of Alldata
Old Jul 29, 2010 | 09:58 AM
brettj2408's Avatar
brettj2408
-Change engine oil and engine oil filter at interval shown or 3 months, whichever comes first.
-Rotate tires.
-Flush and replace engine coolant at 60 months, or 102, 000 miles (170 000 km) whichever comes first.
-Drain and refill transfer case
-Replace spark plugs
-Replace spark plug wires.
-Replace PCV.
-Drain and refill automatic transmission fluid and change both filters.
-Replace Differential Fluid (front and rear)
13.1 quarts - MOPARŽ Antifreeze/Coolant 5 Year/100,000 Mile Formula HOAT (Hybrid Organic Additive Technology)
6 quarts - MOPARŽ API Certified SAE 5W-20 engine oil, meeting the requirements of Chrysler Material Standard MS-6395.
8 plugs - ChampionŽ Nickel - 56028236AA (RC12MCC4) - gap: . 040"
7 quarts - (buy 8 quarts just in case) MOPARŽ ATF+4 Automatic Transmission Fluid
3.4 Pints - NV243 - MOPARŽ ATF+4 Automatic Transmission Fluid
4.0 Pints - (probably dont have) *NV271/NV273 - MOPARŽ ATF+4 Automatic Transmission Fluid
3.4 Pints - C205FD Front Axle - MOPARŽ Synthetic Gear Lubricant SAE 75W-90
4.43 Pints - 9.25 Rear Axle (ANTI-SPIN) - MOPARŽ Synthetic Gear Lubricant SAE 75W-140
**Limited-Slip Rear Axles require the addition of 118 ml (4 oz.) MOPARŽ Limited Slip Additive.
HOPE THIS HELPS
