i have a couple of questions...
Old Aug 3, 2010 | 11:26 AM
wade0323's Avatar
wade0323
Default i have a couple of questions...
ok, i have a 2008 1/2 ton with a 4.7.
#1. my truck only has 62k miles. i was changing the rear end fluid this weekend and realized that my pinion seal is leaking.
has anybody had this issue?
what about replacing it, im the kinda guy that does everything myself, i hate paying other ppl to work on my stuff. does anybody know how hard it is to change out?
#2. my a/c controls in the dash bezzel. i think the lights on the inside that light up the controls are burning out. they seem really dim at night time, almost where i cant see them.
once again, does anyone know how to change the bulbs? i havent looked at it yet, but any advise will be grealty appreciated....
thanks guys!
Old Aug 3, 2010 | 12:19 PM
wade0323's Avatar
wade0323
anybody?
Old Aug 3, 2010 | 12:54 PM
kx250frider617's Avatar
kx250frider617
I dont know about the seal becuase I never have done one but for the dash lights, There are a bunch of guys that changed to colored bulbs so try searching that. Search something like "Blue dash lights"
Old Aug 3, 2010 | 02:50 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You have to take the tires off, brakes, calipers, then pull the diff cover, remove the axle clips and pull out the axles, then the differential assembly and the pinion is there behind it. While you are there you might as well replace the axle seals as well.
AC control lights can be found here. Take the space out of the link so it will work
http://www.dodge talk.com/forums/showthread.php?t=202529&highlight=5135537AA
