Grounding question??
Old Aug 3, 2010 | 03:56 PM
ljhopp's Avatar
ljhopp
Default Grounding question??
After looking at some of wiring diagrams in the haynes manuel I noticed that I didn't put some of the grounds back in the factory location. Would this affect anything? Or should I be alright as long has everything is grounded. I grounded the pcm to the engine hoist stud and the battery to body ground to the engine.
Old Aug 3, 2010 | 04:26 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As long as they are short, clean engine or frame grounds I do not see the issue. You do not want sheet metal grounds or grounds that are long or dirty or the paint not cleaned from around the ground.
Old Aug 3, 2010 | 04:33 PM
Freakinkeith806's Avatar
Freakinkeith806
They should be fine
Old Aug 3, 2010 | 05:20 PM
ljhopp's Avatar
ljhopp
Thanks!!!
