02 Ram 1500 5.9L misfire codes
Old Aug 4, 2010 | 11:41 PM
livalot4's Avatar
livalot4
Default 02 Ram 1500 5.9L misfire codes
I have had a problem with my 02 5.9L for about a month now. The original problem was the o2 sensor, which I changed both of those. didn't fix the problem. Then i had the injectors flushed and cleaned. didn't fix the problem? the misfire was coming form the 2 and 4 cylinders which the plugs got fouled out, changed all 8 plugs. I did a full tune up on the truck, the truck worked good about a week, then it all happened again with a misfire in the 1 and 8 (which are the first two in the firing order), took the motor up to 2500 rpm (misfire range) and sprayed a little ether in the air cleaner to see if it would smooth out the misfire temporarly and it did! so I am guessing that the 1 and possibly the 8 injectors are not functioning properly? will this fix the problem changing the injectors?? I know it is not the crank sensor, the truck has only died on me once and started back up, and the tach didn't go out at that time either. I am hopeful that someone can really help my headache that i have had for a month now. (
Old Aug 5, 2010 | 07:37 PM
lastrights's Avatar
lastrights
plug 8 gets clogged easy, look down throttle body for oil, if there is your gasket is leaking , theres a plate there inbetween the block and the manifold and lets oil in. and will clogged plugs and other bad stuff,
have you noticed a loss of gas milage and performance if so thats your problem
also what plugs are you running, the magnum motors are very picky about plugs
Old Aug 6, 2010 | 06:40 PM
livalot4's Avatar
livalot4
I am running the oem champion plugs. I didn't notice oil in the throttle body? but I will have more time this weekend to look at that aspect more. If there IS oil in that trottle body portion, that will cause a misfire in the particular cylinders? or might still be the fuel injectors? I did flush out the fuel rails since there isn't a fricken fuel filter as well.
Old Aug 6, 2010 | 07:57 PM
jim swanson's Avatar
jim swanson
my buddy's 02 did the same thing and it was his fuel injectors was bad he put new ones on and his problem went away ?
