3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Since you have an '04 like me, check the inside of the glove compartment door - there may be a sticker there that tells you which one you have. It's most likely a 3.55 or 3.92. Also, if it hasn't been worn away, mine has a tag hanging from the rear axle near that right spring mount or wheel that says "3.55 open", meaning that it's a 3.55:1 axle ratio with an open (non-limited slip) differrential.
