hemi engine weak links...
Old Aug 8, 2010 | 03:07 PM
cyclone429's Avatar
cyclone429
Default hemi engine weak links...
As a hemi puts on the miles and is off warranty, what engine componets have a history of going south? If you had to rebuild a 5.7 hemi, what can the after market offer in terms of a stronger crank, aftermarket heads, cam shaft, long blocks, short blocks, ect.
If I keep my rig, I would like to know off any potential issues down the road, I'm by no means wanting the sky to fall down and aside from the 16 sparkys, I enjoy driving the hemi.
Old Aug 8, 2010 | 03:10 PM
nh5's Avatar
nh5
I know the early hemis had valve spring issues but that was fixed supposedly by 04
Old Aug 8, 2010 | 05:12 PM
outcast's Avatar
outcast
timing chain tensioners first thing to check
Old Aug 8, 2010 | 09:47 PM
Duroc's Avatar
Duroc
Stroker kit if it ever needs a rebuild.
Old Aug 8, 2010 | 11:34 PM
cyclone429's Avatar
cyclone429
my hemi is okay, gets the ticks now and than, but its a hemi...
when adding a 6.1 cam give you more stroke in a stock hemi?
Old Aug 9, 2010 | 09:45 AM
brettj2408's Avatar
brettj2408
egr valves always go.
valve springs on early build 03's
plugs every 30k
wires every 60k
hemi's are a very good engine.
Old Aug 9, 2010 | 10:20 AM
HammerZ71's Avatar
HammerZ71
I'd never consider the 6.1 cam for a QC or a 4x4 and certainly not if it was both. It's a high rev, higher end rpm cam with nice HP gains up high in the rpm band that sacrifices low end torque to achieve this. Last thing you wanna do in a heavy 4x4 is give up low end torque.
It's a cam much better suited to a Hemi car or maybe a lowered, street 2wd RC truck...
