exhaust heat shield loose
Old Aug 15, 2010 | 03:06 AM
Marx's Avatar
Marx
Default exhaust heat shield loose
the heat shield on my exhaust headers are only attached by 1 bolt and make a slight ting sound, i can hear it at idle.
Do i need the heat shields?
are they expensive?
are they held on by the header bolts?
Old Aug 15, 2010 | 07:42 AM
abarmby's Avatar
abarmby
Subscribed, as I have exactly the same on my 03 Hemi drivers side stock manifold heat shields.
Old Aug 15, 2010 | 11:20 AM
glass3222's Avatar
glass3222
It probably means the your manifold bolts (the bolt head broke off) are broke and you probably have an exhaust leak at the manifolds. That happened to mine, and that gives you a good excuse to get headers.
Old Aug 16, 2010 | 12:56 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah I would do as said above and check each and every manifold bolt and tighten or replace as needed. However, it the shields or studs are bad, they shields are not required or needed. They are not deflecting that much heat.
Old Aug 16, 2010 | 01:02 AM
Marx's Avatar
Marx
thats what i like to hear, are these bolts torqued?
Old Aug 24, 2010 | 08:14 PM
JamesVT's Avatar
JamesVT
Had the same issue, been getting a rattling noise at about 2100 - 2200 RPM. Removed heatshields thinking they were the issue, as they were only held on by one bolt, then found that I still have the issue, could a leak at this location cause a rattle noise? even after heat sheilds are removed? ALSO: It will only do it under a load, I cannot duplicate the noise sitting still. Sorry to Threadjack, just really need some advice.
Old Aug 24, 2010 | 08:44 PM
HammerZ71's Avatar
HammerZ71
Check them bolts! Bad problem with them snapping on these trucks. Getting a broke steel bolt out of aluminum = fun, fun, fun!!!
