Will not start
I have a ram that will not run sometimes when you try to start. It acts like it is running till you let go of the key. If you hold the the gas down it will run and then after a few minutes everything is fine. It would show any codes excepet for once when it showed crankposition sensor. Replaced it ran good for two weeks. Then started again and I was told it was the ignition switch. Ran good for a month and now has acted up again. If someone has any help, I would be greatful.
Welcome to DF.
The model year of Ram, what engine it has, etc. (general info) about your truck would be very helpful in giving you some ideas. After I get that info, I can also move you to a more appropriate section. 2nd Gen Ram is for 1994-2001 Dodge Rams, 2001-2008 is for 3rd Gen Dodge Rams, etc.
