Code p0456??
I have an 03 ram 2500 5.7.I keep getting code p0456(evap leak monitor 0.020 leak detected) when i reach half a tank of gas.I replaced the gas cap thinking that might be it but of course it wasn't. Anyone have any ideas what i should look for?
Thanks for the help guys
Have you checked the rubber hoses that go into your evap canister underneath the bottom of the truck near the fuel tank?
Check the hoses for dry rot.
Replace if necessary.
If you can't get the dealer part hoses, just use vacuum hose with hose clips. Cheap and easy fix.
Al.
Al.
