limited slip detriot true trac help!
Old Aug 17, 2010 | 10:54 PM
kkuzmicki14's Avatar
kkuzmicki14
Default limited slip detriot true trac help!
Hi I have a 2005 dodge ram 1500 hemi 2wd with 4.88 rear gears in it and i want to buy the detroit true trec limited slip. I was wondering if anyone knows if its compatible with the 4.88 gears?
Old Aug 18, 2010 | 02:46 AM
abarmby's Avatar
abarmby
Yes it should be.
I can't think why it wouldn't be?
BTW.....I bet with the 4:88 rear, that thing is a pig to stop spinning a peg leg?
Al.
Old Aug 18, 2010 | 06:19 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah it would work. What size rims and tires are you running that you wanted or needed 488s?
Old Aug 18, 2010 | 08:52 AM
kkuzmicki14
thank you...I am currently running 35s on 20 inch rims 325/60/r20 I"m debating to move up to 37's...I also have a t56 magnum with the following gear ratios...2.97,,2.10,,1.43,,1.00,,.74,,.50...
Old Aug 18, 2010 | 09:06 AM
dirtydog's Avatar
dirtydog
Moderate User
Yes for the Truetrac. http://www.jegs.com/i/Detroit-Locker...ductId=1032953
2:76-7:56 gear ratio's
No for the Locker as it only goes up to 4:56's http://www.jegs.com/i/Detroit+Locker...C172A/10002/-1
