Clicking noise from underside
Old Aug 20, 2010 | 09:31 PM
wmkmun's Avatar
wmkmun
Default Clicking noise from underside
I have a 2002, 2500, V10. Just started hearing a clicking noise from the underside while the vehicle is moving. Noise frequency changes with vehicle speed. Is this a common indication of a bad U joint or should I be looking at something else? Thanks!
Old Aug 21, 2010 | 01:17 AM
PETE_YK's Avatar
PETE_YK
Yup, check your front u-joints. If you have to replace them get MOPAR, trust me they fit much better than aftermarket u-joints.
Old Sep 22, 2010 | 03:44 PM
BLSCHMITZ's Avatar
BLSCHMITZ
Just picked up an '04 2500, and a couple days later, started hearing the exact same thing, a clicking sound coming from the transfer case area that changes with RPM. It does not do it if I engage 4H though, so is it the FWD or Rear u-joint on the transfer case?
Did you end up replacing yours, and did it fix it?
Old Sep 22, 2010 | 05:26 PM
Blacksport's Avatar
Blacksport
Originally Posted by wmkmun
i have a 2002, 2500, v10. Just started hearing a clicking noise from the underside while the vehicle is moving. Noise frequency changes with vehicle speed. Is this a common indication of a bad u joint or should i be looking at something else? Thanks!
v10?????
Old Sep 22, 2010 | 10:55 PM
KUhawkFAN's Avatar
KUhawkFAN
Originally Posted by Blacksport
v10?????
its a 2nd gen not a 3rd gen
Old Sep 23, 2010 | 12:38 PM
BLSCHMITZ's Avatar
BLSCHMITZ
2004 2500 HD, 5.7L Hemi V8 QC, Short Bed, Auto
